Create an IPv6 Access List
Use this procedure to create an FHS IPv6 access list or add IPv6 prefixes to the existing IPv6 access list.
- In the navigation pane, expand Configuration—> IPv6.
- Select FHS.
- Select the IPv6 Access List tab.
- Select Insert.
- Configure the parameters for the IPv6 access list.
- Select Insert.
IPv6 Access List Field Descriptions
Use the data in the following table to use the IPv6 Access List tab.
| Name | Description |
| Name | Specify the IPv6 access list name to create the IPv6 access list. |
| Prefix | Specify the IPv6 prefix for adding it to the IPv6 access list. |
| PrefixMaskLen | Specify the prefix length for adding it to the IPv6 access list. The value range is from 0 to 128. By default, the value is 0. |
| MaskLenFrom | Specify the start mask length for providing the IPv6 range. The value range is from 0 to 128. By default, the value is set to the configured prefix length of the IPv6 access list entry. |
| MaskLenTo | Specify the end mask length for providing the IPv6 range. The value range is from 0 to 128. By default, the value is set to the configured prefix length of the IPv6 access list entry. |
| AccessType | Select the access type to allow or deny the entry. By default, the access type is allow. |
                        MaskLenFrom and MaskLenTo must always be greater than or equal to the configured PrefixMaskLen for this IPv6 access list entry
                        The MaskLenFrom value must always be less than or equal to the MaskLenTo value.
